Introduction
Damaged touch screen of a mobile phone may render the device useless as it disables the touch function in the affected zone or at times the entire screen. Using this guide, damaged touch screen of a Samsung galaxy S2 mobile phone can be easily replaced at home using standard tools. This guide also provides information about the major components used in a mobile phone and the handling precautions to be taken during disassembly. Replacement of screen must be carried out extremely carefully to avoid damage to other delicate components.
Ce dont vous avez besoin
Gently remove the back cover starting from the slot given on the right side.
Use a magnetic philips #0 head screw driver to open the 7 x 1/16 in (1.6 mm) philips head screws shown in the image.
Repeat the same procedure from step 15 to remove the volume up down button.
Now the main board is free. Carefully lift it up and place on the workbench gently.
Peel off the ribbon cable connecting the charging port and microphone by hand.
Remove the two 2.0 mm screws using the Phillips #0 screwdriver.
Lift the microphone gently.
Lift the board out from the metal casing and place on the workbench.
Finally push the screen out applying force through the screwdriver at the highlighted locations.
Take out the screen, clean the remaining double side tape and adhesive.
Install the new screen and follow the same steps in reverse order to re assemble the phone.
3 autres ont terminé cette réparation.
