Aller au contenu principal
Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Rear Case: étape 1, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Rear Case: étape 1, image 2 de 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 2, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 2, image 2 de 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 3, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 3, image 2 de 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 4, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 4, image 2 de 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 5, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 5, image 2 de 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Battery: étape 6, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Battery: étape 6, image 2 de 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 7, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 7, image 2 de 2
    • Remove the battery.
  8. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: étape 8, image 1 de 3 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: étape 8, image 2 de 3 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: étape 8, image 3 de 3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 9, image 1 de 3 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 9, image 2 de 3 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 9, image 3 de 3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: étape 10, image 1 de 3 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: étape 10, image 2 de 3 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: étape 10, image 3 de 3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 11, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 11, image 2 de 2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  12. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Plastic Midframe: étape 12, image 1 de 1
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  13. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 13, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 13, image 2 de 2
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
  14. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: étape 14, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: étape 14, image 2 de 2
    • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
    • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
  15. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 15, image 1 de 2 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 15, image 2 de 2
    • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
    • Gently pry the headphone jack/speaker assembly up from the front assembly.
  16. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: étape 16, image 1 de 1
    • Lift the headphone jack/speaker assembly out of the Galaxy S III.
98 autres ont terminé cette réparation.
11 commentaires
Thanks for the guide. It's the most detailed that I have seen so far. I'm looking for a headphone jack assembly replacement part that is compatible with a verizon s3 (i535), but they are difficult to find. Some of the sellers on ebay are advertising that their replacement for the i9300 is compatible with the i535, but I am not sure. Can you please tell me where you purchased your headphone jack assembly replacement?
Thanks!
Wendy
Wendy - Réponse
I completed the tutorial but still have sound through the left and only on the right when I spin the jack AND apply pressure towards the phone. The part was brand new and all connections look good at a glance. I must have missed something though. Any ideas?
Nick - Réponse
i had the same problem (no sound through the right ear)
i followed the repair guide, teared it apart and then, when i had the jack out of it i used a flashlight and a soldering iron
my guide:
use a very thin soldering iron, make it really hot, put very much solder on it
then stick it in the jack you have to be VERY FAST!!! otherwise the plastic will melt
now you have solder on the contacts and they touch the headphone plug again :)
worked fine for me, but only do this when you know how to solder!
it's a little risky but it's worth it
cheers
Markus
markuslindner1 - Réponse
Ich habe mir das Teil besorgt und wollte es einbauen, habe aber 2 Schreuben nicht aufgedreht bekommen. Jetzt ist der Kopf ausgenudelt. Was kann ich machen?
atzeborg - Réponse
Thanks for the guide. We just replaced speaker assembly in my son's S3 with a $9 part off ebay, and it's working perfectly. Everything went like the pictures except there was slight difference between original and replacement. The hole next to the speaker in the replacement was a full circle, as in the last photo above, but the original was just a half-circle. We had to trim and file the replacement to match. Once we did that, it all snapped back together like new.
Greg - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 18
Total : 91,202
