Introduction
Use this guide to replace the SIM card.
Pièces
Aucune pièce nécessaire.
The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a  tool to best avoid breaking any clips along the perimeter of the rear case. Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
  • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
  • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
  • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Ajouter un commentaire
Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone. Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case. Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
Pry along the top right side, and continue prying down the right side of the rear case. Pry along the top right side, and continue prying down the right side of the rear case.
  • Pry along the top right side, and continue prying down the right side of the rear case.
Lift up and remove the rear case from the phone. You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  • Lift up and remove the rear case from the phone.
  • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
very easy to follow instructions clear and concise
Deric JONES - Réponse
This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to. Wedge a plastic opening tool into the small notch above the battery.
  • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
  • Wedge a plastic opening tool into the small notch above the battery.
  • Pry the battery up out of its recess.
Remove the battery. Remove the battery.
  • Remove the battery.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click. After the click, release the card and it will pop out of its slot. For reassembly, push the SIM card into the slot until it clicks in place.
  • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
  • After the click, release the card and it will pop out of its slot.
  • For reassembly, push the SIM card into the slot until it clicks in place.
Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it. Grasp and remove the SIM card away from the phone. Grasp and remove the SIM card away from the phone.
  • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
  • Grasp and remove the SIM card away from the phone.
36 autre(s) ont terminé cette réparation.
Voir les statistiques:
Dernières 24 heures : 14
7 derniers jours : 88
30 derniers jours : 410
Total : 79,242
