Aller au contenu principal
Samsung Galaxy S Vibrant Midframe Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S Vibrant Midframe Replacement, Battery: étape 1, image 1 de 3 Samsung Galaxy S Vibrant Midframe Replacement, Battery: étape 1, image 2 de 3 Samsung Galaxy S Vibrant Midframe Replacement, Battery: étape 1, image 3 de 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Midframe Replacement: étape 2, image 1 de 2 Samsung Galaxy S Vibrant Midframe Replacement: étape 2, image 2 de 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Midframe Replacement, Midframe: étape 3, image 1 de 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Midframe Replacement: étape 4, image 1 de 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Midframe Replacement: étape 5, image 1 de 3 Samsung Galaxy S Vibrant Midframe Replacement: étape 5, image 2 de 3 Samsung Galaxy S Vibrant Midframe Replacement: étape 5, image 3 de 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Midframe Replacement: étape 6, image 1 de 2 Samsung Galaxy S Vibrant Midframe Replacement: étape 6, image 2 de 2
    • Slide the SD card out of its slot.
3 autres ont terminé cette réparation.
Krista Purser
Membre depuis le 01/17/13
212 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-37, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,545
