Aller au contenu principal
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
Ce dont vous avez besoin
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: étape 1, image 1 de 1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 2, image 1 de 1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 3, image 1 de 1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: étape 4, image 1 de 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: étape 4, image 2 de 2
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: étape 5, image 1 de 1
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: étape 6, image 1 de 1
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 7, image 1 de 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 7, image 2 de 2
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 8, image 1 de 1
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 9, image 1 de 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 9, image 2 de 2
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 10, image 1 de 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 10, image 2 de 2
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 11, image 1 de 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 11, image 2 de 2
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 12, image 1 de 3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 12, image 2 de 3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 12, image 3 de 3
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 13, image 1 de 2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: étape 13, image 2 de 2
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
3 autres ont terminé cette réparation.
Richard
Membre depuis le 02/07/17
29 758 Réputation
11 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
16 567 tutoriels rédigés
Un commentaire
Thank You so much!
Peter Handless - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 29
Total : 5,160
