Introduction
No background is needed to take out or replace the battery. Taking out or replacing the battery is a very easy procedure to follow, but it is an essential prerequisite for removing other components in the phone.
Pièces
Aucune pièce nécessaire.
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera. Gently pry and twist the flexible rear cover off the back of the phone. Gently pry and twist the flexible rear cover off the back of the phone.
  • Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
  • Gently pry and twist the flexible rear cover off the back of the phone.
Great looking guide with well lit pictures and very concise bullet points.
Rusbell Gonzalez - Réponse
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward. Remove the battery away from the phone. Remove the battery away from the phone.
  • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
  • Remove the battery away from the phone.
Ajouter un commentaire
To install the new battery, follow these instructions in reverse order.
8 autre(s) ont terminé cette réparation.
Nils David Corrales Tovar
Membre depuis le 22/09/2014
2 791 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-5, Hickman Fall 2014
USFT-HICKMAN-F14S1G5
3 membres
7 tutoriels rédigés
Awesome! I called around to the “WeFixYourPhone” places and they told me that battery couldn’t be replaced in a Samsung S5 Active, or they’d replace it for $40 if I bought the battery. Battery $13.50 for a 3200 mAmp one, Amazon Primed it to me. And the 45 seconds to replace it is no joke. That’s all it took. It took longer to get the Otter Box off the phone.
Lisa Swager - Réponse
Voir les statistiques:
Dernières 24 heures : 10
7 derniers jours : 69
30 derniers jours : 268
Total : 20,772
