Introduction
The removal of the SIM card is a very simple process and tools are required to complete the objective. You can also use this guide to remove the MicroSD card. The MicroSD card would follow the same procedure as the SIM card since it goes in the slot that is just on top.
Pièces
Aucune pièce nécessaire.
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera. Gently pry and twist the flexible rear cover off the back of the phone. Gently pry and twist the flexible rear cover off the back of the phone.
  • Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
  • Gently pry and twist the flexible rear cover off the back of the phone.
Great looking guide with well lit pictures and very concise bullet points.
Rusbell Gonzalez - Réponse
Use your fingers to remove the SIM card Use your fingers to remove the SIM card Use your fingers to remove the SIM card
  • Use your fingers to remove the SIM card
Ajouter un commentaire
8 autre(s) ont terminé cette réparation.
Nils David Corrales Tovar
Membre depuis le 22/09/2014
2 791 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-5, Hickman Fall 2014
USFT-HICKMAN-F14S1G5
3 membres
7 tutoriels rédigés
You need to remove the battery to remove the Sim card, but you do not need to remove the battery for the micro Sd card
Jj Fish - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 26
30 derniers jours : 98
Total : 10,964
