Introduction
Use this guide either to replace a damaged rear glass panel on your Samsung Galaxy S6 Edge+, or to remove it for access to other components.
Removing the rear glass destroys the adhesive holding it in place. The adhesive will need to be replaced before the rear glass is reinstalled.
Heat an iOpener and apply it to the volume button side of the phone for about two minutes.
  • Heat an iOpener and apply it to the volume button side of the phone for about two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
Ajouter un commentaire
Once the back panel is hot to the touch, apply a suction cup near the center of the phone, and as close as possible to the edge of the panel. Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap. Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
  • Once the back panel is hot to the touch, apply a suction cup near the center of the phone, and as close as possible to the edge of the panel.
  • Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Slide the pick along the side of the phone to cut the adhesive securing the rear panel. Go slowly so that the pick doesn't slip out of the seam. If cutting becomes difficult, reheat and reapply the iOpener. Go slowly so that the pick doesn't slip out of the seam. If cutting becomes difficult, reheat and reapply the iOpener.
  • Slide the pick along the side of the phone to cut the adhesive securing the rear panel.
    • Go slowly so that the pick doesn't slip out of the seam. If cutting becomes difficult, reheat and reapply the iOpener.
Repeat the heating and cutting procedure for the remaining three sides of the phone. Leave an opening pick under each edge to prevent the adhesive from resealing. Leave an opening pick under each edge to prevent the adhesive from resealing.
  • Repeat the heating and cutting procedure for the remaining three sides of the phone.
  • Leave an opening pick under each edge to prevent the adhesive from resealing.
Use an opening pick to slice through any remaining adhesive. Remove the rear glass.
  • Use an opening pick to slice through any remaining adhesive.
  • Remove the rear glass.
  • To reinstall the back cover:
    • First use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
    • Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. The sheet is asymmetrical, so make sure the screw holes in the adhesive sheet line up with the screws on the frame before applying the adhesive.
      • If the adhesive sheet is not available, you can use a high-bond double-sided tape, such as Tesa 61395.
    • After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
Adam O'Camb
Membre depuis le 11/04/2015
25 382 Réputation
295 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
114 membres
5 916 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 66
Total : 126
