Introduction
This guide will teach you how to replace the rear camera on the Samsung Galaxy S7 Active.
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
  • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
  • Your phone is hot, please do not touch it with your bare hand.
Ajouter un commentaire
Wedge the metal spudger in between the screen and the frame to begin separating them.
  • Wedge the metal spudger in between the screen and the frame to begin separating them.
  • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
  • Your phone might no longer be watertight after you reassemble it.
Slide the metal spudger around the phone at least once. It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  • Slide the metal spudger around the phone at least once.
  • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
Lift the screen up with your hands.
  • Lift the screen up with your hands.
  • Please wash your hands thoroughly with hot water and soap after you finish.
Use a Phillips #000 screwdriver to remove a single screw.
  • Use a Phillips #000 screwdriver to remove a single screw.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use tweezers to remove the small plastic cover you just unscrewed.
  • Use tweezers to remove the small plastic cover you just unscrewed.
Use tweezers to remove the other small plastic cover.
  • Use tweezers to remove the other small plastic cover.
Use a Phillips head #000 to take out the eleven screws marked in the photo.
  • Use a Phillips head #000 to take out the eleven screws marked in the photo.
Use tweezers to disconnect the marked pieces from the motherboard.
  • Use tweezers to disconnect the marked pieces from the motherboard.
Use tweezers to take out the middle button and its connection to the motherboard.
  • Use tweezers to take out the middle button and its connection to the motherboard.
Use a metal spudger to pull the mid frame and battery off of the motherboard. Use a metal spudger to pull the mid frame and battery off of the motherboard. Use a metal spudger to pull the mid frame and battery off of the motherboard.
  • Use a metal spudger to pull the mid frame and battery off of the motherboard.
Use a metal spudger to remove the battery from the midframe. Use a metal spudger to remove the battery from the midframe.
  • Use a metal spudger to remove the battery from the midframe.
Use tweezers to disconnect the front camera from the battery.
  • Use tweezers to disconnect the front camera from the battery.
  • The connector should unsnap similar to a lego piece.
Joe De Leone
Membre depuis le 18/04/2018
253 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 46
Total : 76
