Introduction
This guide will teach you how to pry open your screen through the front side of the phone.
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
  • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
  • Your phone is hot, please do not touch it with your bare hand.
Ajouter un commentaire
Wedge the metal spudger in between the screen and the frame to begin separating them.
  • Wedge the metal spudger in between the screen and the frame to begin separating them.
  • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
  • Your phone might no longer be watertight after you reassemble it.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Slide the metal spudger around the phone at least once. It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  • Slide the metal spudger around the phone at least once.
  • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
Lift the screen up with your hands.
  • Lift the screen up with your hands.
  • Please wash your hands thoroughly with hot water and soap after you finish.
Use the tweezers to disconnect the screen from the phone by detaching the connection. Use the tweezers to disconnect the screen from the phone by detaching the connection. Use the tweezers to disconnect the screen from the phone by detaching the connection.
  • Use the tweezers to disconnect the screen from the phone by detaching the connection.
Clean the rest of the adhesive left on the phone by scraping it off with a metal tool. Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin. Lightly proceed to clean the phone with that napkin.
  • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
  • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
  • Lightly proceed to clean the phone with that napkin.
Erick Vazquez
Membre depuis le 18/04/2018
135 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 14
7 derniers jours : 46
30 derniers jours : 139
Total : 187
