Aller au contenu principal
Samsung Galaxy SIII Mini VE Battery Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: étape 1, image 1 de 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: étape 1, image 2 de 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: étape 1, image 3 de 3
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: étape 2, image 1 de 2 Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: étape 2, image 2 de 2
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: étape 3, image 1 de 2 Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: étape 3, image 2 de 2
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
9 autres ont terminé cette réparation.
Megan
Membre depuis le 10/23/14
1 186 Réputation
6 tutoriels rédigés
Équipe
Michigan Tech, Team 1-8, Lauer Fall 2014 Membre de l'équipe Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 3,307
