Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart. Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
  • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Separating the back cover was the hardest part of the procedure for me (a retired electrical/software engineer). I used a large flat screwdriver blade instead of the hard plastic tool shown. Go slow all the way around the tablet and expect pops as the pieces separate. I was not able to re-connect the back cover completely, accepting a paper-thin gap about 30% around the cover, but it is secure.
Rick Nungester - Réponse
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands. Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
Peter how do I know which charging port I need thank you I don't know how else to reach you Tom Patrick mlc@earthlink.net all small case and no spaces thank you
Tom Patrick - Réponse
Yikes. I began carefully prizing off the screen - but when it finally came away the connector (near the top of the screen, about 1” from the right side) got ripped, so the unit is damaged beyond repair. I think it would have been helpful if your guide had warned us about this possibility and given some advice about how to make sure it doesn’t happen. I now have a broken tablet and a brand new battery, likewise of no use to me. Pretty heartbroken - the unit had been working fine, mainstay of daily use.
goodone - Réponse
For any future people repairing their tablets. DO NOT REMOVE THE SCREEN. I thought my tablet was a Tab 2, but no it was a Tab 3. No heat guns needed. I ended up cracking my screen a bit. I don’t know the extent of the damage yet, but Im probably going to get a replacement screen. You need to pop out the whole thing. Not just the front screen. The reason being that there’s a sort of metal scaffolding holding the screen and the back together. This needs to be separated to put in the new charging port.
Matt -
To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port. Note: the connection lifts up to remove
  • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
  • Note: the connection lifts up to remove
Ajouter un commentaire
After the battery is disconnected you may use your hands to pull out the battery. It may be a little difficult because there is adhesive on the backside of the battery.
  • After the battery is disconnected you may use your hands to pull out the battery. It may be a little difficult because there is adhesive on the backside of the battery.
You don't have to, just be careful with battery connector.
Kyoko Hori - Réponse
You have to be very careful with the battery connector. On mine, the plug was difficult to remove from the base and I ended up breaking the connections between the base and the circuit board. Maybe use the pry tool to hold the base down while easing out the plug.
Hugh Morrison - Réponse
I just did the same thing Hugh...does that mean my tablet is trashed? Can it be repaired?
tlibert -
Disconnect the relays attached to the motherboard. Disconnect the relays attached to the motherboard. Disconnect the relays attached to the motherboard.
  • Disconnect the relays attached to the motherboard.
Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver,  then lift the speakers from the device. Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver,  then lift the speakers from the device. Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver,  then lift the speakers from the device.
  • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
2 autre(s) ont terminé cette réparation.
Kyle Ballard
Membre depuis le 22/09/2014
714 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 4-2, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 membres
20 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 29
Total : 1,087
