Aller au contenu principal
Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: étape 1, image 1 de 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Battery: étape 1, image 2 de 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: étape 2, image 1 de 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: étape 4, image 1 de 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: étape 5, image 1 de 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: étape 6, image 1 de 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: étape 7, image 1 de 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement, Micro USB Port: étape 7, image 2 de 2
    • Remove the two 2.7mm Phillips #00 screws from the micro USB port.
    • Remove the micro USB retaining bracket.
  8. Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: étape 8, image 1 de 2 Samsung Galaxy Tab 4 10.1 Micro USB Port Replacement: étape 8, image 2 de 2
    • Use the flat end of a spudger to disconnect the micro USB port.
    • Remove the micro USB port.
12 autres ont terminé cette réparation.
Blake Klein
Membre depuis le 01/29/17
70 583 Réputation
50 tutoriels rédigés
2 commentaires
Thank you so much for simplifying this guide for us novices. I have tried watching two videos where they assume I already have some Samsung repair knowledge. I feel confident I will be able to get the tablet up and charging in no time.
Stacie Harper - Réponse
There is no need to remove the battery, only detach the power connector, cheers!
Bartosz Kaczynski - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 43
Total : 7,049
