Introduction
If the vibration motor in your Samsung Galaxy tab 4 8.0 stops working, you may need to replace it. Before deciding to replace the vibration motor, check to make sure the phone isn't on Do Not Disturb or Silent Mode as these may stop the vibrate notification.
The vibration motor is a small electric motor. The vibration motor will last for quite a long time. The standard in the industry is 100k cycles with 1 second on and 1 second off.
Prior to beginning this repair, make sure your phone is powered off and you remove the battery,
Ce dont vous avez besoin
At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
Use the angled tweezers to lift up the orange rectangular electrical connector, this will disconnect the vibration motor from the motherboard.
