Introduction
Use this guide to replace the audio jack when it either ceases to function, or is functioning incorrectly.
Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
  • Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
Ajouter un commentaire
Detach the connector that connects the audio jack to the flex cable.
  • Detach the connector that connects the audio jack to the flex cable.
Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
  • Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
Pick up and remove the defective audio jack. Pick up and remove the defective audio jack.
  • Pick up and remove the defective audio jack.
2 autre(s) ont terminé cette réparation.
Stephanie Wong
Membre depuis le 26/09/2014
892 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 13-2, Staggers Fall 2014 Membre de l'équipe USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 501
