Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
Ajouter un commentaire
Detach the ribbon cable.
  • Detach the ribbon cable.
Disconnect the thin connector wire. Note the position both ends go to. There is a similar connection at one end of the wire that could be confused for the correct connection. Incorrectly reconnecting the wire upon re-assembly to this terminal will result in a malfunctioning unit! Disconnect the thin connector wire. Note the position both ends go to. There is a similar connection at one end of the wire that could be confused for the correct connection. Incorrectly reconnecting the wire upon re-assembly to this terminal will result in a malfunctioning unit!
  • Disconnect the thin connector wire. Note the position both ends go to. There is a similar connection at one end of the wire that could be confused for the correct connection. Incorrectly reconnecting the wire upon re-assembly to this terminal will result in a malfunctioning unit!
Remove the 4 screws securing the motherboard. Remove the 4 screws securing the motherboard. Remove the 4 screws securing the motherboard.
  • Remove the 4 screws securing the motherboard.
Replace the original motherboard with the new circuit board. Replace the original motherboard with the new circuit board.
  • Replace the original motherboard with the new circuit board.
2 autre(s) ont terminé cette réparation.
Stephanie Wong
Membre depuis le 26/09/2014
892 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 13-2, Staggers Fall 2014 Membre de l'équipe USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 membres
5 tutoriels rédigés
Thanks for this post.
But, that was the speaker module and docking port assembly, not the motherboard!
The title is misleading!
valuesphilippines - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 26
Total : 2,452
