Introduction
If your display is unresponsive or cracked, this is the guide for you! As you follow the steps below, please be careful to not damage the other components.
Insert a metal spudger between the back case and the screen of the device.
  • Insert a metal spudger between the back case and the screen of the device.
  • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
  • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
Ajouter un commentaire
Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place. Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
Place one hand on the battery and grasp the outer edge of the device with the other hand. Flip the device over so that the battery falls over and onto your hand.
  • Place one hand on the battery and grasp the outer edge of the device with the other hand.
  • Flip the device over so that the battery falls over and onto your hand.
Pull the battery out until it is only connected to the device by the black, yellow, and red connectors. Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
Hold the battery and grip the wires with your thumb and finger. Pull the wires away from the device to remove the white connector from the black socket.
  • Hold the battery and grip the wires with your thumb and finger.
  • Pull the wires away from the device to remove the white connector from the black socket.
  • Lift the battery away from the device.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the green tape that is covering the ZIF connections. Remove the green tape that is covering the ZIF connections.
  • Remove the green tape that is covering the ZIF connections.
Use a plastic opening tool to lift the black tab on both ZIF connectors. Use a plastic opening tool to lift the black tab on both ZIF connectors.
  • Use a plastic opening tool to lift the black tab on both ZIF connectors.
Use a spudger to release the display flex able from the ZIF connector. Pull out the front facing camera. Pull out the front facing camera.
  • Use a spudger to release the display flex able from the ZIF connector.
  • Pull out the front facing camera.
Undo the press connectors with a plastic opening tool. Undo the press connectors with a plastic opening tool.
  • Undo the press connectors with a plastic opening tool.
Remove the two 2.8mm screws holding in the magnetic brackets with a PH00 bit.
  • Remove the two 2.8mm screws holding in the magnetic brackets with a PH00 bit.
Pull out the two magnetic brackets. Pull out the two magnetic brackets.
  • Pull out the two magnetic brackets.
Remove the four 2.8mm screws holding in the daughterboard with a PH00 bit.
  • Remove the four 2.8mm screws holding in the daughterboard with a PH00 bit.
Use a spudger to help lift up the daughterboard. There is some glue so pry carefully.
  • Use a spudger to help lift up the daughterboard.
    • There is some glue so pry carefully.
  • Remove the daughterboard.
Remove the four 2.8mm screws holding in the motherboard with a PH00 bit.
  • Remove the four 2.8mm screws holding in the motherboard with a PH00 bit.
Pull out the motherboard.
  • Pull out the motherboard.
Blake Klein
Membre depuis le 29/01/2017
30 299 Réputation
19 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
114 membres
5 916 tutoriels rédigés
Hi Blake, this stops before getting to the screen?
Tom Kell - Réponse
lollllllll.. this is incomplete
mrdamnslow - Réponse
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 40
30 derniers jours : 211
Total : 1,236
