Introduction
This guide will walk you through the process of replacing a broken home button in a Samsung Gear 2.
Before disassembling your Gear, be sure it is powered off. To remove each strap, locate the metal latches on both sides of the back of the Gear.
  • Before disassembling your Gear, be sure it is powered off.
  • To remove each strap, locate the metal latches on both sides of the back of the Gear.
  • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Ajouter un commentaire
Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components. Pry the device open from the other side also if it does not fully disassemble from one side. Pry the device open from the other side also if it does not fully disassemble from one side.
  • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
  • Pry the device open from the other side also if it does not fully disassemble from one side.
Locate the rectangular metal connector that attaches the camera to the Gear. Use tweezers to gently lift and detach the metal plate of the connector.
  • Locate the rectangular metal connector that attaches the camera to the Gear.
  • Use tweezers to gently lift and detach the metal plate of the connector.
  • When reassembling the Gear, reattach the camera connector by carefully aligning the metal plate and its pins to its original placement. Make sure it snaps in place to avoid improper connections and possible damage.
Use tweezers to carefully lift the camera from its slot out of the case.
  • Use tweezers to carefully lift the camera from its slot out of the case.
Cool! But were can i buy a camara for the watch?
jorge - Réponse
Did you find a place to buy the camera? Mine broke today
warakurna -
Use tweezers to grab and then gently lift up the metal plate of the safety belt. When removing the metal plate, be sure to remove them carefully as to not rip the orange tape that is attached to them.
  • Use tweezers to grab and then gently lift up the metal plate of the safety belt.
  • When removing the metal plate, be sure to remove them carefully as to not rip the orange tape that is attached to them.
  • During reassembly, be sure to line up the pins of the metal plate in order to reattach correctly.
There are actually TWO metal plates attached on mine, not one, but they both came away easily, and were both easy to put back.
anthony - Réponse
Once the safety belt is removed, use tweezers to take the motherboard out of the Gear 2. Once the safety belt is removed, use tweezers to take the motherboard out of the Gear 2.
  • Once the safety belt is removed, use tweezers to take the motherboard out of the Gear 2.
Insert the spudger into the small opening underneath the black home button assembly and pry it off the casing. Lift up to detach the black assembly.
  • Insert the spudger into the small opening underneath the black home button assembly and pry it off the casing.
  • Lift up to detach the black assembly.
  • Be sure not to rip the orange tape that keeps the home button assembly attached to the device.
Use tweezers to grab the orange connector that is attached to side the home button assembly and lift to remove it from its adhesive. Use tweezers to grab the orange connector that is attached to side the home button assembly and lift to remove it from its adhesive.
  • Use tweezers to grab the orange connector that is attached to side the home button assembly and lift to remove it from its adhesive.
Using two spudgers, place the pointed tips at each end of the U-shaped snap ring located under where the home button assembly was. Remove the snap ring by pushing down with both pointed objects on each side of the ring simultaneously, it should pop off. Be careful not to lose the snap ring because it can be lost easily.
  • Using two spudgers, place the pointed tips at each end of the U-shaped snap ring located under where the home button assembly was.
  • Remove the snap ring by pushing down with both pointed objects on each side of the ring simultaneously, it should pop off.
  • Be careful not to lose the snap ring because it can be lost easily.
  • To replace the snap ring, rest it above the home button peg using tweezers so the open side rests on the peg. Then use the flat end of the spudger and push firmly down on the snap ring to snap it back onto the peg as shown in the last picture.
Use either the tweezers or the spudger to push the button peg out through the hole.
  • Use either the tweezers or the spudger to push the button peg out through the hole.
Allison Michel
Membre depuis le 14/04/2014
486 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 13-27, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 26
Total : 2,592
