Aller au contenu principal
Samsung Jack Antenna Replacement
Ce dont vous avez besoin
  1. Samsung Jack Antenna Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Antenna Replacement: étape 2, image 1 de 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Antenna Replacement, Rear Case: étape 3, image 1 de 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Antenna Replacement: étape 4, image 1 de 3 Samsung Jack Antenna Replacement: étape 4, image 2 de 3 Samsung Jack Antenna Replacement: étape 4, image 3 de 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Antenna Replacement: étape 5, image 1 de 1
    • Lift the rear case off of the phone.
  6. Samsung Jack Antenna Replacement, Antenna: étape 6, image 1 de 1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. Samsung Jack Antenna Replacement: étape 7, image 1 de 3 Samsung Jack Antenna Replacement: étape 7, image 2 de 3 Samsung Jack Antenna Replacement: étape 7, image 3 de 3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
Paul Piller
Membre depuis le 04/12/11
56 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 24-57, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 2,331
