Introduction
Use this guide to install a rear case.
Pièces
Aucune pièce nécessaire.
Slide the battery cover downwards with pressure focused on the center of the cover.
  • Slide the battery cover downwards with pressure focused on the center of the cover.
  • Lift the cover off of the phone.
Ajouter un commentaire
Grasp the bottom left and right corners of the battery and lift it from its housing.
  • Grasp the bottom left and right corners of the battery and lift it from its housing.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool in between the front and rear cases. Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
  • Insert the Plastic Opening Tool in between the front and rear cases.
  • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
Lift the rear case off of the phone.
  • Lift the rear case off of the phone.
Paul Piller
Membre depuis le 12/04/2011
56 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 24-57, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,058
