Aller au contenu principal
Samsung NP540U3C-A02UB Battery Replacement
Ce dont vous avez besoin
  1. Samsung NP540U3C-A02UB Battery Replacement, Hard Drive: étape 1, image 1 de 1
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Battery Replacement: étape 2, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement: étape 2, image 2 de 2
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Battery Replacement: étape 3, image 1 de 3 Samsung NP540U3C-A02UB Battery Replacement: étape 3, image 2 de 3 Samsung NP540U3C-A02UB Battery Replacement: étape 3, image 3 de 3
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Battery Replacement: étape 4, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement: étape 4, image 2 de 2
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Battery Replacement: étape 5, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement: étape 5, image 2 de 2
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Battery Replacement: étape 6, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement: étape 6, image 2 de 2
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Battery Replacement, Battery: étape 7, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement, Battery: étape 7, image 2 de 2
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Battery Replacement: étape 8, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement: étape 8, image 2 de 2
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Battery Replacement: étape 9, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement: étape 9, image 2 de 2
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Battery Replacement: étape 10, image 1 de 1
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Battery Replacement: étape 11, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement: étape 11, image 2 de 2
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Battery Replacement: étape 12, image 1 de 3 Samsung NP540U3C-A02UB Battery Replacement: étape 12, image 2 de 3 Samsung NP540U3C-A02UB Battery Replacement: étape 12, image 3 de 3
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Battery Replacement: étape 13, image 1 de 2 Samsung NP540U3C-A02UB Battery Replacement: étape 13, image 2 de 2
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Battery Replacement: étape 14, image 1 de 1
    • Remove the battery from the laptop.
Alejandro
Membre depuis le 03/28/22
253 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team C-1, Gurgel Spring 2022 Membre de l'équipe UMass Dartmouth, Team C-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SCG1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 8
30 derniers jours : 26
Total : 883
