Introduction
Should either the memory card reader, USB or HDMI ports become unresponsive or otherwise damaged, it will be necessary to replace the motherboard. This guide will show how to replace the camera's motherboard.
Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera. Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
  • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
Ajouter un commentaire
Using a Phillips #00 precision screwdriver, remove the last 4mm screw located inside the input ports' compartment.
  • Using a Phillips #00 precision screwdriver, remove the last 4mm screw located inside the input ports' compartment.
I've tried this before and I remember this screw not coming off why is this?
Jun Hong - Réponse
Hello Jun. If you are using the correct screwdriver, there may be a few answers to your question:
The camera screw is stuck:
This happened to the team that did this project, just keep working with the screwdriver until it comes loose.
The camera screw lost threads:
If a screw is screwed in incorrectly, it could be permanently lodged in the camera and you will be unable to open it.
The camera screw head is rounded:
If the small pieces of the head (visible) part of the screw are gone with groove marks, the screw is permanently damaged and cannot be removed unless you have special equipment.
Other than these tips, you may need to look elsewhere for more help.
-Victoria
Victoria Leppold - Réponse
Thank you for the quick reply! Does this have to do with it being the last screw to be taken out? do the screws have to be screwed out in this order? Thank you
Jun Hong -
There is no order for removing the screws. However, we did take note it was the most difficult to remove because of it's placement. It is difficult to get a grip on the camera when attempting to loosen this screw, therefore it is more prone to damage. Keep trying, but don't force the screw out to where the part may become damaged by means listed in the previous comment.
-Victoria
Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel. Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
  • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether. To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
  • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
  • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
Hi, I have follow the 4 steps and now my question is about the proper lcd screem. In my case the touch "cristal" is broke do I have to buy all the back side of the camara (with the keys, I mean) o can I take off only the "cristal". I saw in Aliexpress taht they sell all the piece or the "cristal" alone. I do not know how to take out the broken cristal from the back piece. please can you help me. Sorry by my english I am Spanish and I do not now if I did explain properly. Thank you.
cvaragarcia - Réponse
Using a Phillips #00 precision screwdriver, remove the three 4mm screws holding the motherboard in place.
  • Using a Phillips #00 precision screwdriver, remove the three 4mm screws holding the motherboard in place.
Using tweezers or a plastic opening tool, release the locks on the ribbon receptors by flicking up the black bars on the holds. Pull the five ribbons away from the motherboard (one hidden from view). This will free the motherboard completely from the device. To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter. To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
  • Using tweezers or a plastic opening tool, release the locks on the ribbon receptors by flicking up the black bars on the holds. Pull the five ribbons away from the motherboard (one hidden from view). This will free the motherboard completely from the device.
The motherboard is now free. Pull the motherboard up and slightly away from the input compartment; it will lift out easily.
  • The motherboard is now free. Pull the motherboard up and slightly away from the input compartment; it will lift out easily.
5 autre(s) ont terminé cette réparation.
Andres Perez
Membre depuis le 21/01/2015
816 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 9-6, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 9-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G6
4 membres
5 tutoriels rédigés
any suggestions where to get the board? i oly found one on aliexpress for $100
Sergei Levitan - Réponse
I have a nx300 that wont switch on (green power light flickers when battery inserted) do you know if there is an internal fuse which can be replaced?
cheers
Tom
Tom - Réponse
I suggest you should buy a replacement motherboard to have your full functional operations.
yaksyari - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 40
Total : 1,799
