Outils recommandés dans ce démontage
Introduction
Samsung SGH-A117 is a basic flip phone. This guide will describe the steps required for disassembling and reassembling the phone.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Samsung SGH-A117, utilisez notre manuel de réparation.
This is the Samsung SGH-A117.
  • This is the Samsung SGH-A117.
Ajouter un commentaire
This is the back view following the removal of the back cover and battery.
  • This is the back view following the removal of the back cover and battery.
Use a screwdriver to remove screws around the frame.
  • Use a screwdriver to remove screws around the frame.
  • Use a PH00 size screw to operate this step.
  • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover. The end of the phone closest to the hinge will require additional force to lift.
  • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
  • The end of the phone closest to the hinge will require additional force to lift.
  • Be careful not to bend the cover during the removal process.
Use a spudger to gently lift the circuit connector from the logic board.
  • Use a spudger to gently lift the circuit connector from the logic board.
  • Be careful not to remove the circuit connector from the phone.
Use a spudger to lift the logic board and separate it from the main body of the phone. It is recommended to lift from the bottom part of the logic board as shown in the picture.
  • Use a spudger to lift the logic board and separate it from the main body of the phone.
  • It is recommended to lift from the bottom part of the logic board as shown in the picture.
  • Be careful not to lose the volume button, which is loosely attached to the logic board.
Gently push the keyboard from the case as shown in the picture. Gently push the keyboard from the case as shown in the picture.
  • Gently push the keyboard from the case as shown in the picture.
1 Case
  • 1 Case
  • 1 Keyboard
  • 1 Logic Board
  • 1 Volume Control
  • 1 Back Cover
  • 5 Screws
Justin
Membre depuis le 06/10/2014
132 Réputation
2 tutoriels rédigés
Équipe
Aristotle Membre de l'équipe Aristotle
Community
5 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 401
