Introduction
Removing the back cover exposes all the internal components of the laptop. This will void your warranty, so use caution and be sure not to damage any of the components inside.
Make sure your Chromebook is powered off before you begin. Place the laptop on a flat surface with the bottom side facing up.
  • Make sure your Chromebook is powered off before you begin.
  • Place the laptop on a flat surface with the bottom side facing up.
  • Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
  • Remove all the seven screws in the bottom panel.
Ajouter un commentaire
Loosen the back cover panel by using the flathead screwdriver or the spudger. Loosen the back cover panel by using the flathead screwdriver or the spudger.
  • Loosen the back cover panel by using the flathead screwdriver or the spudger.
Once you work your way around, you can remove the panel. Once you work your way around, you can remove the panel.
  • Once you work your way around, you can remove the panel.
Helder Avelino
Membre depuis le 22/10/2013
801 Réputation
5 tutoriels rédigés
Équipe
University of Maryland, Team 1-7, Shastany Fall 2013 Membre de l'équipe University of Maryland, Team 1-7, Shastany Fall 2013
UMD-SHASTANY-F13S1G7
2 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 22
30 derniers jours : 123
Total : 4,389
