Aller au contenu principal
Samsung Series 5 UltraTouch Battery Replacement
Ce dont vous avez besoin
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: étape 1, image 1 de 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: étape 1, image 2 de 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: étape 2, image 1 de 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: étape 2, image 2 de 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: étape 3, image 1 de 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: étape 3, image 2 de 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: étape 4, image 1 de 2 Samsung Series 5 UltraTouch Battery Replacement: étape 4, image 2 de 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: étape 5, image 1 de 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: étape 6, image 1 de 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: étape 7, image 1 de 1
    • Remove the battery from the laptop.
14 autres ont terminé cette réparation.
Timothy
Membre depuis le 01/30/15
1 579 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 16-3, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 membres
5 tutoriels rédigés
2 commentaires
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Réponse
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 47
Total : 26,766
