Aller au contenu principal
Samsung Series 9 NP900X3A Back Panel Replacement
Ce dont vous avez besoin
  1. Samsung Series 9 NP900X3A Back Panel Replacement, Back Panel: étape 1, image 1 de 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Back Panel Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Back Panel Replacement: étape 3, image 1 de 3 Samsung Series 9 NP900X3A Back Panel Replacement: étape 3, image 2 de 3 Samsung Series 9 NP900X3A Back Panel Replacement: étape 3, image 3 de 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
Zahir Sanchez
Membre depuis le 02/08/18
493 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,099
