Introduction
The front camera is on the same side as the phone's screen and is the only camera used to Skype on the Samsung Stratosphere.
Ce dont vous avez besoin
Using your fingers, pry along the groove at the top of the phone.
Pull back on the rear casing until it comes free from the device.
The casing will make a cracking sound as it is removed.
Locate the red and white sim card located above the battery housing.
Remove the sim card by sliding it downwards from its slot with your fingers.
Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
Pry the keyboard away from the casing with the plastic opening tool.
2 autres ont terminé cette réparation.
