Aller au contenu principal
Samsung Stratosphere Rear Camera Replacement
Ce dont vous avez besoin
  1. Samsung Stratosphere Rear Camera Replacement, Battery: étape 1, image 1 de 1
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
  2. Samsung Stratosphere Rear Camera Replacement: étape 2, image 1 de 1
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
  3. Samsung Stratosphere Rear Camera Replacement, Motherboard: étape 3, image 1 de 1
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
  4. Samsung Stratosphere Rear Camera Replacement: étape 4, image 1 de 1
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
  5. Samsung Stratosphere Rear Camera Replacement: étape 5, image 1 de 1
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
  6. Samsung Stratosphere Rear Camera Replacement: étape 6, image 1 de 1
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
  7. Samsung Stratosphere Rear Camera Replacement: étape 7, image 1 de 2 Samsung Stratosphere Rear Camera Replacement: étape 7, image 2 de 2
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
  8. Samsung Stratosphere Rear Camera Replacement: étape 8, image 1 de 1
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
  9. Samsung Stratosphere Rear Camera Replacement, Rear Camera: étape 9, image 1 de 1
    • Gently pull the camera to the left while keeping it as close to the motherboard as possible.
    • The metal foil connector attached to the camera should slide out of the motherboard.
5 autres ont terminé cette réparation.
Ryan
Membre depuis le 10/20/13
375 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-32, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 617
