Aller au contenu principal
Samsung T139 Pad Buttons Replacement
Ce dont vous avez besoin
  1. Samsung T139 Pad Buttons Replacement, Remove Back Cover: étape 1, image 1 de 3 Samsung T139 Pad Buttons Replacement, Remove Back Cover: étape 1, image 2 de 3 Samsung T139 Pad Buttons Replacement, Remove Back Cover: étape 1, image 3 de 3
    • Power off your phone before beginning disassembly
    • Apply pressure to the back cover and slide towards the base
  2. Samsung T139 Pad Buttons Replacement, Remove Battery: étape 2, image 1 de 2 Samsung T139 Pad Buttons Replacement, Remove Battery: étape 2, image 2 de 2
    • With a plastic opening tool, lift and remove the battery
  3. Samsung T139 Pad Buttons Replacement, Remove Screws: étape 3, image 1 de 2 Samsung T139 Pad Buttons Replacement, Remove Screws: étape 3, image 2 de 2
    • Remove the four Phillips 1.0mm #0 screws
  4. Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: étape 4, image 1 de 3 Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: étape 4, image 2 de 3 Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: étape 4, image 3 de 3
    • Using the plastic opening tool, work around the edge of the black plastic cover until it pops off
  5. Samsung T139 Pad Buttons Replacement, Remove Side Buttons: étape 5, image 1 de 2 Samsung T139 Pad Buttons Replacement, Remove Side Buttons: étape 5, image 2 de 2
    • Remove side buttons by lifting them off the board
  6. Samsung T139 Pad Buttons Replacement, Remove Circuit Board: étape 6, image 1 de 1
    • Lift circuit board up gently
    • Be careful to not pull ribbon cord apart when removing
  7. Samsung T139 Pad Buttons Replacement, Remove Button Pad: étape 7, image 1 de 2 Samsung T139 Pad Buttons Replacement, Remove Button Pad: étape 7, image 2 de 2
    • Lift away button pad
Reagan May
Membre depuis le 10/23/14
573 Réputation
5 tutoriels rédigés
Équipe
Michigan Tech, Team 1-1, Lauer Fall 2014 Membre de l'équipe Michigan Tech, Team 1-1, Lauer Fall 2014
MTU-LAUER-F14S1G1
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 342
