Introduction
Use this guide to remove the Wi-Fi module from your device.
Pièces
Aucune pièce nécessaire.
On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
Ajouter un commentaire
From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front. From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it. There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it. There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the cover from the device.
  • Remove the cover from the device.
The wifi module is clipped into place in the corner of the device. There are no screws or adhesives holding it down. The wifi module is clipped into place in the corner of the device. There are no screws or adhesives holding it down.
  • The wifi module is clipped into place in the corner of the device. There are no screws or adhesives holding it down.
There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out. There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out. There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out.
  • There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out.
Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand. Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand. Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand.
  • Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand.
James Edwards
Membre depuis le 01/02/2018
627 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team S2-G1, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G1, Johnson Spring 2018
BU-JOHNSON-S18S2G1
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 43
