Aller au contenu principal
SanDisk Sansa C250 Rear Case Cover Replacement
Ce dont vous avez besoin
  1. SanDisk Sansa C250 Rear Case Cover Replacement, Battery Cover: étape 1, image 1 de 1
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Rear Case Cover Replacement: étape 2, image 1 de 1
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Rear Case Cover Replacement, Battery: étape 3, image 1 de 1
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Rear Case Cover Replacement: étape 4, image 1 de 1
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Rear Case Cover Replacement: étape 5, image 1 de 1
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Rear Case Cover Replacement, Rear Case Cover: étape 6, image 1 de 1
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Rear Case Cover Replacement: étape 7, image 1 de 1
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Rear Case Cover Replacement: étape 8, image 1 de 1
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Rear Case Cover Replacement: étape 9, image 1 de 1
    • The rear case cover can now be separated from the device.
Nicolas Coffey
Membre depuis le 01/27/12
43 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 3-30, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 851
