Introduction
This guide will help you remove and replace the LCD screen.
Pièces
Aucune pièce nécessaire.
Remove the five case screws with a Phillips #00 Screwdriver. Five 3.5mm Phillips Screws Five 3.5mm Phillips Screws
  • Remove the five case screws with a Phillips #00 Screwdriver.
  • Five 3.5mm Phillips Screws
Ajouter un commentaire
Gently lift up the back cover and set aside.
  • Gently lift up the back cover and set aside.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector. Be careful not to rip out the ribbon connector.
  • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
  • Be careful not to rip out the ribbon connector.
To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger. Gently lift ribbon out of the gate and set screen aside.
  • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
  • Gently lift ribbon out of the gate and set screen aside.
Anthony Giardina
Membre depuis le 19/04/2010
20 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 7-10, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 4,883
