Introduction
A guide to remove the Logic Board from the Sega Dreamcast.
Ce dont vous avez besoin
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Remove the white fan header by gently pulling it away from from the controller port.
Remove the five 10mm Philips #02 screws from left side of the logic board cover.
Remove the three black 12mm Philips #02 screws from the right side of the logic board cover.
22 autres ont terminé cette réparation.
Un commentaire
helpful but my dreamcast had a different logic board and as well as fan and gd-rom so keep that in mind if u see something different in your unit
