Introduction
This repair guide will take you through all the steps for removing the outer case of the Sega Genesis.
Pièces
Aucune pièce nécessaire.
Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
Ajouter un commentaire
Flip the Sega Genesis upright.
  • Flip the Sega Genesis upright.
Gently lift the top casing.
  • Gently lift the top casing.
  • Note: the case will be connected to the main board by LED wires.
Bend out the LED leads into vertical positions.
  • Bend out the LED leads into vertical positions.
Slide the LED wire apparatus off the lead pins.
  • Slide the LED wire apparatus off the lead pins.
  • Note: observe which color wire corresponds with which length of pin.
Separate the main board from the outer case.
  • Separate the main board from the outer case.
11 autre(s) ont terminé cette réparation.
Erik Bjornstrom
Membre depuis le 04/10/2010
650 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-29, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 32
30 derniers jours : 103
Total : 13,529
