Introduction
To access the motors, the belt, and the motherboard of the vacuum, some of the screws on the back panel have to be removed. This guide will show you how to remove the screws from the back panel on your Shark Rocket Powerhead AH401.
Pièces
Aucune pièce nécessaire.
Ensure the device is turned off and unplugged from any power source before beginning work. Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover. Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
  • Ensure the device is turned off and unplugged from any power source before beginning work.
  • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
  • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
  • Lift the brushroll cover upward.
Ajouter un commentaire
Lift the brushroll out by pulling the tab labeled "pull". Lift the brushroll out by pulling the tab labeled "pull".
  • Lift the brushroll out by pulling the tab labeled "pull".
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Ensure the device is turned off and unplugged from any power source before beginning work. Push down on the dust can lever to release the dust can in order to get to the filter grill. Push down on the dust can lever to release the dust can in order to get to the filter grill.
  • Push down on the dust can lever to release the dust can in order to get to the filter grill.
Remove the dust cup by lifting it off the dock. Remove the dust cup by lifting it off the dock.
  • Remove the dust cup by lifting it off the dock.
Flip the device over so that the bottom is face up. Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
  • Flip the device over so that the bottom is face up.
  • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
Toan Pham
Membre depuis le 24/01/2018
242 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S19-G3, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 68
