Pièces
Aucune pièce nécessaire.
Place the TV face down on a flat smooth surface as to not scratch the screen. Remove the four 8mm screws attaching the stand to the TV.
  • Place the TV face down on a flat smooth surface as to not scratch the screen.
  • Remove the four 8mm screws attaching the stand to the TV.
Ajouter un commentaire
Lift the stand off the television. Lift the stand off the television.
  • Lift the stand off the television.
Remove the two back panels to display the audio and video inputs.. Remove the two back panels to display the audio and video inputs.. Remove the two back panels to display the audio and video inputs..
  • Remove the two back panels to display the audio and video inputs..
Remove the eight 6mm Phillips screws around the edge. Remove the two 6mm Phillips near the inputs.
  • Remove the eight 6mm Phillips screws around the edge.
  • Remove the two 6mm Phillips near the inputs.
Lift and remove the back case of the television.
  • Lift and remove the back case of the television.
Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
  • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
Remove the green and gray power connector from the side of the buttons panel at the top of the television. Remove the green/gray to orange/gray connector from the center of the circuit board.
  • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
  • Remove the green/gray to orange/gray connector from the center of the circuit board.
Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case. Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
Flip the LCD/circuit board so that the circuit board faces up.
  • Flip the LCD/circuit board so that the circuit board faces up.
Remove the three 5mm Philips screws attaching the circuit board to the LCD. Remove the five 6mm Phillips screws from the edges of the circuit board attacking it to the LCD. Remove the five 6mm Phillips screws from the edges of the circuit board attacking it to the LCD.
  • Remove the three 5mm Philips screws attaching the circuit board to the LCD.
  • Remove the five 6mm Phillips screws from the edges of the circuit board attacking it to the LCD.
Turn the circuit board so the blue and pink side cables are facing you. Hold the white plastic, squeeze and pull from the  sides. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  • Turn the circuit board so the blue and pink side cables are facing you.
  • Hold the white plastic, squeeze and pull from the sides.
Turn the television so the right hand side is facing you. To remove the ribbon cables, fold the brown casing down and pull directly upward on the ribbon. Turn the television so the left hand side is facing you, and remove the ribbon cable in the same manner.
  • Turn the television so the right hand side is facing you.
  • To remove the ribbon cables, fold the brown casing down and pull directly upward on the ribbon.
  • Turn the television so the left hand side is facing you, and remove the ribbon cable in the same manner.
Turn the circuit board so that the left side is facing you. Detach the data cable from the circuit board. To do this, slide your finger nail from the middle of the connector until the little black tabs rotates down toward the board as shown in the second picture.
  • Turn the circuit board so that the left side is facing you.
  • Detach the data cable from the circuit board.
  • To do this, slide your finger nail from the middle of the connector until the little black tabs rotates down toward the board as shown in the second picture.
Lift and remove the circuit board from the LCD frame.
  • Lift and remove the circuit board from the LCD frame.
Now you have your LCD.
  • Now you have your LCD.
2 autre(s) ont terminé cette réparation.
Robert Hobson
Membre depuis le 20/01/2011
1 275 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 1-11, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 5
7 derniers jours : 22
30 derniers jours : 84
Total : 6,288
