Introduction
Outline what you are going to teach someone how to do.
Pièces
Aucune pièce nécessaire.
Place the TV face down on a flat smooth surface as to not scratch the screen. Remove the four 8mm screws attaching the stand to the TV.
  • Place the TV face down on a flat smooth surface as to not scratch the screen.
  • Remove the four 8mm screws attaching the stand to the TV.
Ajouter un commentaire
Lift the stand off the television. Lift the stand off the television.
  • Lift the stand off the television.
Remove the two back panels to display the audio and video inputs.. Remove the two back panels to display the audio and video inputs.. Remove the two back panels to display the audio and video inputs..
  • Remove the two back panels to display the audio and video inputs..
Remove the eight 6mm Phillips screws around the edge. Remove the two 6mm Phillips near the inputs.
  • Remove the eight 6mm Phillips screws around the edge.
  • Remove the two 6mm Phillips near the inputs.
Lift and remove the back case of the television.
  • Lift and remove the back case of the television.
Remove the eight 9mm screws from both speakers. DO NOT remove speakers yet - they are still attached.
  • Remove the eight 9mm screws from both speakers.
  • DO NOT remove speakers yet - they are still attached.
Remove the two speaker cables from the circuit board by pinching the plastic connectors and firmly pulling up. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  • Remove the two speaker cables from the circuit board by pinching the plastic connectors and firmly pulling up.
  • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
Remove the two black tape strips (one on each side) securing the power cable to the frame. The speakers can now be removed.
  • Remove the two black tape strips (one on each side) securing the power cable to the frame.
  • The speakers can now be removed.
Robert Hobson
Membre depuis le 20/01/2011
1 275 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 1-11, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 22
Total : 3,659
