Aller au contenu principal
Sharp PC-MM20 Keyboard Replacement
Ce dont vous avez besoin
  1. Sharp PC-MM20 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • First, remove the battery from your laptop and make sure it is powered down.
  2. Sharp PC-MM20 Keyboard Replacement: étape 2, image 1 de 2 Sharp PC-MM20 Keyboard Replacement: étape 2, image 2 de 2
    • Close your laptop
    • Turn your laptop so that the back of it is facing you.
    • You should notice three screw. Remove those screws using the proper screw driver.
    • Be sure to put them somewhere safe, like a magnetic pad for instance.
  3. Sharp PC-MM20 Keyboard Replacement: étape 3, image 1 de 1
    • Now, we're going to flip the laptop so it is upside down.
    • Remove the screws shown in the picture as well.
  4. Sharp PC-MM20 Keyboard Replacement: étape 4, image 1 de 2 Sharp PC-MM20 Keyboard Replacement: étape 4, image 2 de 2
    • Next, open the laptop and focus on the front of the base of the laptop.
    • Notice that there are small notches in between the two plates of the laptop
    • Take a flat edge and wedge it into the slot, and pop it open. There should be several of these slots on the front side of the laptop.
  5. Sharp PC-MM20 Keyboard Replacement: étape 5, image 1 de 2 Sharp PC-MM20 Keyboard Replacement: étape 5, image 2 de 2
    • Once the cover is loose, you should be able to wiggle it somewhat freely. However, there are a few connections holding it together.
    • Next, we're going to use tweezers to delicately remove the flat cable connecting the key board to the laptop.
    • Also, remove the flat cable from the track pad to the laptop.
  6. Sharp PC-MM20 Keyboard Replacement: étape 6, image 1 de 1
    • Now that all connections are undone, you should be able to easily remove the top of the base from the rest of the computer.
  7. Sharp PC-MM20 Keyboard Replacement: étape 7, image 1 de 1
    • Next, you can take the key board out of its housing, and replace it with your new key board!
Logan Lindsey
Membre depuis le 09/11/13
101 Réputation
1 tutoriel rédigé
Équipe
Oakland University, Team 1-1, Ruszkiewicz Fall 2012 Membre de l'équipe Oakland University, Team 1-1, Ruszkiewicz Fall 2012
OAK-RUSZKIEWICZ-F12S1G1
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 557
