Aller au contenu principal
Sharper Image SBT5002 Speaker Replacement
Ce dont vous avez besoin
  1. Sharper Image SBT5002 Speaker Replacement, Back Panel: étape 1, image 1 de 2 Sharper Image SBT5002 Speaker Replacement, Back Panel: étape 1, image 2 de 2
    • Unplug the speaker before doing any work on it.
    • Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
  2. Sharper Image SBT5002 Speaker Replacement: étape 2, image 1 de 1
    • Remove the back panel.
  3. Sharper Image SBT5002 Speaker Replacement, Speaker: étape 3, image 1 de 1
    • Remove the snap cable that connects the speaker to the circuit board.
  4. Sharper Image SBT5002 Speaker Replacement: étape 4, image 1 de 2 Sharper Image SBT5002 Speaker Replacement: étape 4, image 2 de 2
    • Use a tap hammer and a punch to release the 4 posts that hold the front panel in place.
  5. Sharper Image SBT5002 Speaker Replacement: étape 5, image 1 de 2 Sharper Image SBT5002 Speaker Replacement: étape 5, image 2 de 2
    • Use a plastic opening tool or spudger to pry off the front panel.
  6. Sharper Image SBT5002 Speaker Replacement: étape 6, image 1 de 1
    • Use a#4 Phillips screwdriver to remove the four 9.5mm screws that secure the subwoofer to the woofer box.
  7. Sharper Image SBT5002 Speaker Replacement: étape 7, image 1 de 1
    • Remove the defective speaker.
Linda Freund
Membre depuis le 08/06/17
235 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 535
