Introduction
This guide will show you how to replace the LED lights inside the device. There is soldering required, so if you need assistant please read this soldering technique page.
Gently position the device so that the buttons and speakers lie face down. Unplug the power cord from the "DC Input."
  • Gently position the device so that the buttons and speakers lie face down.
  • Unplug the power cord from the "DC Input."
Ajouter un commentaire
Remove the four 12mm phillips head #2 screws located along the outer edge of the white case. Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together. Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
  • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
  • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
  • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
  • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
  • A small gap will open as the two tabs are released.
  • Do not pull the two halves apart yet. They are held together by the speaker wire.
Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter. Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
  • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
  • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
  • Lay the device down, so that all the internal components are facing upwards.
Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out. Wiggling the connector back and forth as you pull will make removal easier.
  • Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out.
  • Wiggling the connector back and forth as you pull will make removal easier.
Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case. Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
  • Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
Remove the four 7mm Phillips #1 screws on the circuit board with the LED lights. Slowly lift the circuit board out of the front cover and place the cover out of the way.
  • Remove the four 7mm Phillips #1 screws on the circuit board with the LED lights.
  • Slowly lift the circuit board out of the front cover and place the cover out of the way.
Remove the solder connecting the LED light that needs replacement. Remove the solder connecting the LED light that needs replacement.
  • Remove the solder connecting the LED light that needs replacement.
Melissa Pasa
Membre depuis le 13/10/2013
701 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 11-33, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 11-33, Amido Fall 2013
CPSU-AMIDO-F13S11G33
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 225
