Introduction
The collar is the place the top and bottom of the microphone screw together. After unscrewing it, you will have access to most of the internal parts of the microphone.
Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it. Be careful to not pull on the collar or you may rip the wires from the faceplate. Be careful to not pull on the collar or you may rip the wires from the faceplate.
  • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
  • Be careful to not pull on the collar or you may rip the wires from the faceplate.
Ajouter un commentaire
nat coll
Membre depuis le 27/09/2012
366 Réputation
17 tutoriels rédigés
Équipe
Cal Poly, Team 7-53, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 membres
18 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 79
Total : 7,096
