Aller au contenu principal
Skil 88 Motor Housing Replacement
Ce dont vous avez besoin
  1. Skil 88 Motor Housing Replacement, Disassembling Skil 88 Front Housing: étape 1, image 1 de 1
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Skil 88 Motor Housing Replacement: étape 2, image 1 de 2 Skil 88 Motor Housing Replacement: étape 2, image 2 de 2
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Skil 88 Motor Housing Replacement, Trigger Housing: étape 3, image 1 de 2 Skil 88 Motor Housing Replacement, Trigger Housing: étape 3, image 2 de 2
    • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
  4. Skil 88 Motor Housing Replacement: étape 4, image 1 de 3 Skil 88 Motor Housing Replacement: étape 4, image 2 de 3 Skil 88 Motor Housing Replacement: étape 4, image 3 de 3
    • Separate the cord from the handle.
  5. Skil 88 Motor Housing Replacement, Motor Housing: étape 5, image 1 de 2 Skil 88 Motor Housing Replacement, Motor Housing: étape 5, image 2 de 2
    • Remove the inner divider.
  6. Skil 88 Motor Housing Replacement: étape 6, image 1 de 1
    • Remove the two 1" flathead screws located at the top and bottom of the motor housing.
  7. Skil 88 Motor Housing Replacement: étape 7, image 1 de 2 Skil 88 Motor Housing Replacement: étape 7, image 2 de 2
    • Pull the motor housing out.
    • The wires from the trigger housing should follow the motor housing.
  8. Skil 88 Motor Housing Replacement: étape 8, image 1 de 2 Skil 88 Motor Housing Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • After you have placed the motor housing back into the drill during reassembly, thread the wires down to the handle using tweezers.
    • Plug the forked wire into the socket at the back of the motor housing using tweezers.
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
Membre depuis le 10/10/10
365 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-17, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 21
Total : 2,906
