Aller au contenu principal
Skil 88 Motor Replacement
Ce dont vous avez besoin
  1. Skil 88 Motor Replacement, Disassembling Skil 88 Front Housing: étape 1, image 1 de 1
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Skil 88 Motor Replacement: étape 2, image 1 de 2 Skil 88 Motor Replacement: étape 2, image 2 de 2
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Skil 88 Motor Replacement, Motor: étape 3, image 1 de 2 Skil 88 Motor Replacement, Motor: étape 3, image 2 de 2
    • Remove the gear that is threaded onto the divider.
  4. Skil 88 Motor Replacement: étape 4, image 1 de 2 Skil 88 Motor Replacement: étape 4, image 2 de 2
    • Remove the divider from the rear housing.
    • The motor may come out along with the divider.
  5. Skil 88 Motor Replacement: étape 5, image 1 de 2 Skil 88 Motor Replacement: étape 5, image 2 de 2
    • Pull out the motor.
  6. Skil 88 Motor Replacement: étape 6, image 1 de 3 Skil 88 Motor Replacement: étape 6, image 2 de 3 Skil 88 Motor Replacement: étape 6, image 3 de 3
    • For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
    • Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
    • Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
Membre depuis le 10/10/10
365 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-17, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 634
