Introduction
After opening the trigger housing, one of the things you can do is replace and remove the trigger mechanism. It's as simple as getting the housing open.
Outils
Pièces
Aucune pièce nécessaire.
Use the socket wrench to remove the 0.5" length screw from the bottom of the handle. Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
  • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
Ajouter un commentaire
Separate the cord from the handle. Separate the cord from the handle. Separate the cord from the handle.
  • Separate the cord from the handle.
Make sure that the drill is completely unplugged.
  • Make sure that the drill is completely unplugged.
  • Locate the two wires attached to the black trigger.
  • Pull the wires out of the trigger. It may take a bit of force.
Push the wires into the new trigger piece.
  • Push the wires into the new trigger piece.
  • Make sure the wires go back into the correct holes.
Matt
Membre depuis le 10/10/2010
365 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-17, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 2,318
