Aller au contenu principal
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: étape 1, image 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: étape 1, image 2 de 2
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: étape 2, image 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: étape 2, image 2 de 2
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: étape 3, image 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, spring removal: étape 3, image 2 de 2
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
5 autres ont terminé cette réparation.
Katie Fetters
Membre depuis le 09/17/14
815 Réputation
4 tutoriels rédigés
Équipe
2 commentaires
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Réponse
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 41
Total : 9,904
