Aller au contenu principal
Solio Rocsta Charging Indicator Button Replacement
Ce dont vous avez besoin
  1. Solio Rocsta Charging Indicator Button Replacement, Solio Rocsta Top Cover Disassembly: étape 1, image 1 de 2 Solio Rocsta Charging Indicator Button Replacement, Solio Rocsta Top Cover Disassembly: étape 1, image 2 de 2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Charging Indicator Button Replacement: étape 2, image 1 de 2 Solio Rocsta Charging Indicator Button Replacement: étape 2, image 2 de 2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
  3. Solio Rocsta Charging Indicator Button Replacement, Battery: étape 3, image 1 de 1
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Charging Indicator Button Replacement: étape 4, image 1 de 1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
  5. Solio Rocsta Charging Indicator Button Replacement: étape 5, image 1 de 1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta Charging Indicator Button Replacement, Charging Indicator Button: étape 6, image 1 de 1
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
  7. Solio Rocsta Charging Indicator Button Replacement: étape 7, image 1 de 1
    • With a Soldering Iron desolder the charging indicator button connectors.
    • For more information on how to solder and desolder connections, please visit this guide.
  8. Solio Rocsta Charging Indicator Button Replacement: étape 8, image 1 de 1
    • Gently pry the charging indicator button using one of the Precision Tweezers.
David Vazquez
Membre depuis le 10/10/17
577 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G13, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 96
