Introduction
This guide is for the replacement of the control panel and microphones for the Sonos One.
Disconnect all power cords. Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool. Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
  • Disconnect all power cords.
  • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
Ajouter un commentaire
Remove the four 10mm Torx T10 screws from the bottom of the speaker. Remove the four 10mm Torx T10 screws from the bottom of the speaker. Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers. Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
The protective cover clip is very thin and deforms easily. Remove the single 8mm Torx T10 screw and protective cover clip. Remove the single 8mm Torx T10 screw and protective cover clip.
  • The protective cover clip is very thin and deforms easily.
  • Remove the single 8mm Torx T10 screw and protective cover clip.
Slide the protective cover upwards to remove. Slide the protective cover upwards to remove.
  • Slide the protective cover upwards to remove.
Use the pointed end of a spudger to remove the covers that hide the screws. Remove the four 9mm Torx T8 screws from around the perimeter of the control panel. Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  • Use the pointed end of a spudger to remove the covers that hide the screws.
  • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
With the front of the unit facing you, lift the control panel up using your thumbs. There's a ribbon cable attaching the control panel to the speaker so work slowly.
  • With the front of the unit facing you, lift the control panel up using your thumbs.
  • There's a ribbon cable attaching the control panel to the speaker so work slowly.
Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket. Pull the control panel ribbon cable out of its socket. Pull the control panel ribbon cable out of its socket.
  • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
  • Pull the control panel ribbon cable out of its socket.
Pull the control panel away from the speaker to separate. Pull the control panel away from the speaker to separate.
  • Pull the control panel away from the speaker to separate.
Marcus Glowa
Membre depuis le 14/02/2018
653 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 9
7 derniers jours : 25
30 derniers jours : 43
Total : 110
