Introduction
If you find your waterproof case not as watertight as you had hoped, you might want to replace the O-ring. You will need a tool to pry the O-ring from the case.
Pièces
To open the case, push the yellow "Open" tab located at the bottom of the case.
  • To open the case, push the yellow "Open" tab located at the bottom of the case.
  • Pull out on the yellow tabs as indicated by the circles in the photo to unlock the lid. This may be a little tricky!
  • Then, remove the lid.
Ajouter un commentaire
Take the plastic opening tool and wedge it between the O-ring and the groove.
  • Take the plastic opening tool and wedge it between the O-ring and the groove.
  • Then, pry the O-ring until it is out of the groove.
Now that the O-ring is out of the groove, remove the O-ring from the lid.
  • Now that the O-ring is out of the groove, remove the O-ring from the lid.
Justin Calean
Membre depuis le 09/01/2015
413 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Sullivan Winter 2015 Membre de l'équipe USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 530
