Introduction
This guide will detail the steps necessary to remove the back cover of the Sony Bloggie 3D Player.
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Ajouter un commentaire
Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
  • Use a plastic opening tool to pry the cover open.
  • After the the cover is partly open as shown, remove the cover with your hands.
Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
Use a plastic opening tool to loosen the back cover off the device. Once the back cover is loose, remove it gently by hand.
  • Use a plastic opening tool to loosen the back cover off the device.
  • Once the back cover is loose, remove it gently by hand.
Timothy Tran
Membre depuis le 30/01/2013
1 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-12, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 267
