Introduction
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Ajouter un commentaire
Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
  • Use a plastic opening tool to pry the cover open.
  • After the the cover is partly open as shown, remove the cover with your hands.
Detach the board from the ZIF connector using pair of tweezers or by hand. Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
  • Detach the board from the ZIF connector using pair of tweezers or by hand.
  • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
Robert Tam
Membre depuis le 30/01/2013
6 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-12, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 267
